I have built alot of 440s, and have researched this stuff for 40 plus years. I currently have a 1970 440 with 906 heads, and the pistons only come to about .080" below the deck. With the 906 heads at 88 cc, this would give a C/Ratio of 9.03 to 1. Chrysler claimed 9.5 to 1 on those motors in the 70 Roadrunners, I believe. You can use a 440 six pack piston with a Compression height of 2.067 such as the KB 237, that will get you to about .015" below deck. Then using an 80 CC head, .020 head gasket, you will get about 11 to 1 C/R. So in answer to your question, Chrysler reduced C/R mainly by lowering the deck height, and in the late 70s, (1977 and after) , they lowered the piston to .140 or more below deck, and also put in a dished piston. Then were talking 7.5 to 1! I took the ported 906 heads and 509 cam out of that motor and put them on a 451 with 14 cc dome pistons, and that thing was a screamer at 12.5 to 1 C/R! Next step was 915 heads on the 451 which took it to 13 to 1, and that was REALLY a screamer! We're talking low 12s in a 3600 lb Roadrunner.
