383man
Rumblefish360 is right. You want that vent open at idle and it closes when you step on the gas. Its part of what they call a balanced carb that vents to atmosphere at idle and on the gas it vents thru the carb airhorn so the fuel in the carb bowl has the same balanced venting that the carb airhorn does. Also if its open at idle it will also let fuel fumes out on hot days and help keep the carb from flooding. The bowl vent it not new or only on evap emission cars as the old carbs had them also and they were open to atmosphere at idle. When the closed evap system came around they would keep the fumes from escaping into the air as it vented to a charcoal canister where it held the fumes until the eng purged them out and burnt them. Or on one year around 70 to 71 they vented the bowl vent to the crankcase and then when the eng starts the PCV system pulls the fumes in the eng and burns them. Ron
