Mboller
Lifetime Mopar guy and new to this sight and looking for suggestions on no shift situation. 1967 Coronet with heavy mod 383. Under normal driving conditions the 4 speed shifts fine with an occasional slight grind into second gear. Under a hard launch form 1st to 2nd gear becomes locked out. There is no second gear, you must stop and put back into neutral before it will go into second gear. I have adjusted the shift linkage and replaced the Hurst shift with a new one. Still under hard launch it locks out second gear? I am curious if anyone else had this issue? Wondering if it could be the reverse detent engaging under heavy acceleration? Thanks in advance for any advice what to look at.
