wyrmrider
They should have lived in the Fordgedtrue days, way before all the multi axis skirt grinds
They have three different combustion chamber configurations. 88cc, 84cc and 75cc. Only the 88 is an open chamber. 84 and 75 are closed. The 60919 is the 84cc closed chamber. Don't know how that corresponds to casting numbers. Would be interesting to know.
let's start over
88 cc open chamber heads
edelbrock says "88cc chambers are machined .100" for clearance with quench dome style pistons"
so check out the Icon and Keith Black quench dome style pistons and compare with your pistons
how are you planning on getting some quench?
Also, I will be going with molnar rods which state 6.76 for the length. The Icon pistons I want to go with state 6.768 for the rod length. Does the .008 difference in the "rod length" numbers mean anything?
if you want to do it more right calculate duration at valve open .006
Because it takes the valve lash variable out of the problemWhy is that more right?
.006 at the valve is the SAE recognized way of measuring- also takes rocker ratio into consideration
When using the UEM calculator, and the .050" timing, add the 15 degrees. Other calculators like the Wallace, use the advertised cam duration and the +15 degrees is not used as it is already figured into the calculation.OK forum members, debate this. The UEM (they make Icon and KB pistons) compression calculator asks for 15 degrees of timing to be added to the cam spec. So in my instance it goes from a timing of 44.5 to 59.5. This extra 15 degrees results in a 8.5 DR. Other compression calculators do not ask for an extra 15 degrees and thus output a DR of 9.28.
Which should I believe/use? Add 15 degrees or not?
Yep, solid lifter cams and hydraulic cams with the same duration at .050" lift are two different animals in my opinion.you're better off estimating than using a fixed 15 degrees for a solid lifter cam
if your lash was .015 the lifter would rise .035 at .050 and with a 1.5 rocker over .050
if it was .030 it would only rise .020 and with a 1.5 rocker the valve .030
comparing cams solid cams using .050 gives only a really rough estimate
.050 is useful for degreeing in cams, that's it
