Yes, if those are the correct numbers.
Looks like you managed through the vagueness alright.
The relationship between those numbers is correct on the Wallace calculator, i.e. the 8.0 DCR and 160psi. And if we are using actual seat timing, I don't think it will run on pump gas without detonation.
Here is the real life example.
Static compression: 10:8:1
Actual measured intake closing (0.006" valve off the seat w/ 0.023" lash) 77° ABDC
4.25" arm
7.1" rod
DCR 7.7:1 (From Wallace)
Dynamic cranking pressure 147psi (From Wallace)
This motor has an actual cranking cylinder pressure of 195 psi (0.023" lash) with a standard factory starter, and is on the edge of detonation with some winter blends of 92 octane fuels available locally. You'll have to assume that I don't have something stupid going on with the tune. Pretty hard to imagine that if I put a smaller cam in (10° less total seat timing w/ everything else the same = 8.0:1 DCR) it would run on pump fuel.
And to be clear, my point is simply this, aimlessly stuffing numbers into a calculator and thinking you can conclude definitively something about detonation without some personal basis to draw from in making your conclusions is flawed.
From the Victory Library:
"To sum up: DCR a useful tool, but widely perceived to be of greater worth than can be supported by physics"
