Yep. Great product and good quality.Looks like this is the way to go for replacement….from Stear and GearView attachment 1748859
If you just pull it well out, reinstall the coupler, shaft fully into the coupler and then put the column back in place... you'll probably have to push the column in a tad to get it back in the dash retainer plate and all will be good. Lots of guys driving around with the plastic shear pins gone in the shaft.Really appreciate everyones help…. Any idea what the “gap” should be, between the steering box shaft, and tge column shaft, so I’ll know if i can “uncollapse” the shaft it will be at proper length?
Ok, sounds good….tomorrow’s task. I still don’t know where these “plastic pins” are supposed to be!If you just pull it well out, reinstall the coupler, shaft fully into the coupler and then put the column back in place... you'll probably have to push the column in a tad to get it back in the dash retainer plate and all will be good. Lots of guys driving around with the plastic shear pins gone in the shaft.
I told you where to get educated, guess I've gotta dig up the link myself for you.Ok, sounds good….tomorrow’s task. I still don’t know where these “plastic pins” are supposed to be!
Thanks I ordered new coupler with the newer style seal…fingers crossed!From your pic the shoes and retainer popped off the pin.. they wear over time and will give you slop in the steering wheel. It's best to rebuild it with at least new shoes, retainer clip and seal. Be sure to pack full of grease and carefully bend tabs of cover on. Shoes and retainer circled
And i appreciate your inputI told you were to get educated, guess I've gotta dig up the link myself for you.
Here is a picture. They are called “shear pins”. If I remember correctly, they’re just inside the “outer tube” you can see under the hood. You might (?) be able to see the edge of this transition???Ok, sounds good….tomorrow’s task. I still don’t know where these “plastic pins” are supposed to be!
Thanks! A big help!Here is a picture. They are called “shear pins”. If I remember correctly, they’re just inside the “outer tube” you can see under the hood. You might (?) be able to see the edge of this transition???
As shown in the picture, the right side of the shaft goes “down” (ends up at the cross-pin near the coupler you’re also looking at). This lower section can slide up inside the upper section in a crash, breaking those two white plastic shear pins. You have to remove and rebuild the steering column to get to these. “Technically” you could just put Vice grips on your lower shaft and drive it downwards with a hammer until it slides down to the desired length (crude, but it would work). You’re at the correct length when the steering column is bolted up inside the car & the shaft reaches inside the coupler enough to hold the guts (“shoes”) inside & the coupler sticks down far enough that it locates well in the steering box and the securing pin at the bottom of the coupler is installed. You probably have about 1” to 1-1/2” total “slop to play with” up/down where everything connects well together View attachment 1748926
The roll pin for the steering box end fits in the hole with that clip? Where did you buy this clip?I rebuilt the couple with available kits then installed the Mopar “fix” for these things falling apart. Tight and secure! Two sizes of these I believe 3” / 3.5” so when buying check.
Yes it does. I posted it a few posts backThe roll pin for the steering box end fits in the hole with that clip? Where did you buy this clip?
And get yerself one of these for a little in-surance...
Mopar A B E Body 66-73 Dodge Plymouth 3" STAINLESS Steering Column Coupler Cover Clamp / Retainer
Detroit Muscle Technologies, LLC Mopar restoration gasketswww.detroitmuscletechnologies.com
I assume this can be installed once everything is back together? Or i would have to wait for reassembly until receiving this?Yes it does. I posted it a few posts back
This would be the last thing you do. Put everything back together in the car then put on the retainer on.I assume this can be installed once everything is back together? Or i would have to wait for reassembly until receiving this?
Excellent, thanks everyoneThis would be the last thing you do. Put everything back together in the car then put on the retainer on.
