Ray70Chrg
Here's my take from All the information that I read from this site. When I recently rebuilt the front suspension, I put in the eccentric bushings and set them for maximum caster and my intention is to not adjust them ever again. I now have all the caster that is available from the oem UCA's. I don't even care what the amount of positive caster I have because there is no more. Also, I shimmed the lower ball joints .080" on each side based on what I've read on site. I read @KD's post that he used .125 shim and that may give 2* of adjustment. After putting everything back together with the standard ride height and all the torque specs done with the wheels carrying the weight I drove several times for a total of about 40-50 miles. Did not like the handling as the car pulled to the right. I know the caster is maxed, so time to look at the camber adjustment. like so many others, I have a red-neck tool set up using a 2' level. I have gone to great lengths to convert the bubble indicator and the 2 markings, and based on its 2 ft. length, to get an equivalent degree value. The left wheel, luckily, came in at the 1st mark which indicated a -.3 degrees. The right wheel was off the bubble on the positive side. WTF is this. What I realized, using the 2' level, is I only had to move the bottom of the level out about a 1/4 inch to get the bobble back to the center. So, I disconnected the lower ball joint and added 2 more .08 shims. Put it all together again and road tested about 10 miles. Plenty of speed bumps and drainage trenches in my development to work the suspension. Latest readings on camber is
left wheel: -.6 degrees
right wheel: -.3 degrees
I watched the video last night that @KD provided and it talked about ride height changing slightly just by moving the car around a little bit. When ride height changes so does Camber and caster.
Next, I'm going to order those Toe Plates to see if I can check and adjust toe-in. I didn't mention that after addressing the right wheel with added shims the handling is back to normal.
Thanks to all who have contributed info on this subject. Attached is pic of my camber gauge.
