Aluminum Radiator Options?
Dylan
New Member
7:55 PM
I've got a 67 Charger with the 440 from a 72 Polara (if that makes a difference). The radiator I currently have has fittings for top-right and bottom-left attachment. I'm having trouble determining what will work with my setup, specifically because all "direct fit" radiator options are different dimensions or different alignments than the current one. Anyone have experience with aluminum options and direct or close-to direct fitment?
Dylan
you will need to change your water pump housing to a drivers side inlet for the radiators to work correctly....
Are there not any ways I could make a couple mounting plates and fit one with the same inlets?
