I received my offset dowels (.007) this week and installed them. First crack on the dial indicator read .005 TIR - so .0025 total run out.
View attachment 1810162View attachment 1810163
I know that I'm within required specs (.005), and I'm at .0025, but I may try to get the numbers closer to zero if I can. There are members who have struggled with getting their numbers within specs and have spent a lot of time getting this right, but maybe the stars were just lined up for me.
While I have the trans out, I took the liberty to change out my oil pan from a 4 qt, unbaffled 187 pan to a baffled, 6 qt max wedge pan.
View attachment 1810167View attachment 1810168
Unfortunately, I was unable to keep my windage tray - they don't agree with each other.
As I was installing the new pan, you guessed it, I pulled the threads out of the block on the last pan rail bolt, which also happened to be the hardest one to install (above the cross member). I wasn't going to accept engine removal to fix this, so I was able to install a bolt that was longer than the original and was able the catch enough "good" remaining threads. The last few turns of the socket was a little nerve racking.
