Any ideas on this issue??
Hi, well i see you tried the wooden dowel, that works if there is parts contacting each other (metal rod or pry bar works better,) if its a vacuum leak or belt a length of hose works better to transfer sound, keep it straight no bends, works like speaking to another person through a tube.
You may be able to get a better location.
Yes def did the ol' long screwdriver (stethoscope) trick. Cant quite pinpoint it. When I get some free time I'll see if there is anyway I can eliminate some other items. It's certainly not any sort of vacuum leak. It's a squeal for sure. Hopefully it's not a main bearing...
Try a piece of garden hose. it eliminates most sound except at the open end. keep it straight no bends.
Thanks for the tip. Never tried the garden hose but I believe I am accomplishing the same thing with a screwdriver, although I am curious to try. I also have an actual stethoscope that I bought a while back just for this sort of thing. Have yet to try it out but will do soon enough. Thanks!
A screw driver will show things that are contacting such as a spun bearing, rocker, fuel pump rod. However if the sound IS NOT coming from unwanted contact such as a belt squeal or carb gasket would be. A tube will allow the sound to travel to your ear like talking to another person thought a pipe. Thanks
I've seen some weird noises coming from a cracked flex X plate before. Usually crack around where it bolts to the crank shaft and not to the torque converter. But can see them with the cover off. Good luck.
I really wish musekmkr would have posted if he ever found the problem. Right now, I'm experiencing the exact same problem and I can't find the source of my squealing sound.
I really wish the OP would have posted if he ever found the problem. Right now, I'm experiencing the exact same problem and I can't find the source of my squealing sound.
Have you tried pulling the pcv out of the valvecover
Yes, no change. It sounds like the squealing is towards the front as if it's the front carb making the noise.
They can whistle from the idle circuits.. try turning them a bit. Or plug the air bleeds
