Thanks Kern! I was hoping someone would reply with an example picture! Appreciate this!!!I found that with the brackets on the evaporator, there was at least a 1 1/4" to 1 1/2" space between the evaporator and firewall. I mounted Dwayne's ECM, Ballast Resistor and Voltage regulator with no risk of touching the evaporator when I drilled for the mounting screws.
If you gave the opportunity to paint the firewall block off plate to match the color of the car, do it. This one blends in so well, it looks like it is OEM.
The two guys helping me said to paint the block off plates, but when we were test fitting it was like the brake reinforcement plate is black, so it's not too bad to just keep the block off plate black. This car is a driver and I just convinced myself to keep it black and move on.
