- 12:26 AM
- Nov 20, 2013
- Ft Lauderdale fla.
Think about it..... every one of these cars needs a new set of wires from head to tail lights... however which way you go search the forums and ask... don't wait for a problem to arise and if you have a problem start from scratch... stereo installations and just miles of bouncing around... just age alone. The wires get corrosion from the slightest pin hole and that reduces the amount of conductivity..... go with a size or two fatter wire and the relays and those old switches that are a fortune may last longer.... run a few extra grounds so the sheet metal and spot welds. Dont carry much or any loads use a tinned marine wire for under car and bare metal with a brass bolt and nut and dielectric grease.... wire is getting expensive so the sooner you can do it the cheaper it will be and be through... I wrap everything in friction tape then the regular tape.... if it aint broke don't fix it attitude can be disastrous... prevention is always better in the big picture.....
My $2.02 version...... and we take pay pal....:happy7:
