gtxno1
Hello everyone I am about to overhaul my carb and get it ready for use I am determined to build a sleeper. This what I am doing 67 Gtx 440 flat tops 30over Lunati mechanical cam 264/272 526/546 Indy dual plane intake 915 heads larger valves pocket ported The carb is a 69 avs 4640 I will be using a wideband for setting it up here is the question there are no strip kits for this carb I was thinking about changing over from the 3 step metering rod set up and going with the 2 step because of the availability now the tricky part do I just match up what was in there and install the closest combo or do I pick a combo from an eddy carb like the thunder or the 1407 or 1412 and use that as my base line and make my adjustments as needed. I know at the very least I may have to replace the springs vacuum may be a little lower at idle.
