Dako
This is why I come to this site. :eusa_clap:
The dialog is great without all that :violent1:
If your motor is idling, there should be no ported vacuum, since it is taken above the throttle blades. If you 'wing the throttle' and let it go, you probably still won't see any ported vacuum. However, if you hook up a vacuum gauge with a rubber hose into the driver's compartment so you can see it and then go out on the road and put the motor under load by accelerating hard, you will see ported vacuum. It's how it works. BTW, the info in that article applies to all brands, not just GM. Happy motoring...
