- 4:58 AM
- Jul 17, 2008
- South Jersey USA
coil heating up?
Ran again today, runs super strong, lightning quick throttle response and again about the 13 min. mark started to bang again, not quite as load or strong a few times at idle. Crack throttle open and it roars and no bang.
After I clean all the plugs, it waits till warm and about 13min in to the start upit does it after about 13 minutes? it did this more than once?.......sounds electrical to me
Coil is a stock unit, new like most components, does not seem overly warmcoil heating up?
That might be the ticket, with my 2" headers some of the wires are right up on the exhaust. I saw that early on an I am running each with high quality plug "socks"Misfiring and raw gas is burning/ popping in the hot exhaust. You have a misfire, bad plugs or bad wires, 13 minutes is the time it takes to get the exhaust tubing hot.
Yes, I have been charging battery up between runs and it reads about 13.67 before startingI gotta ask... are you charging the battery back up between these runs??? 12.53 volts certainly doesn't impress me. A static battery, fully charged, should read more than that!
So your alternator is doing squat and 13 minutes in your ignition system goes into clusterfuck mode from low voltage. Leave the charger on the battery and run her up again !Yes, I have been charging battery up between runs and it reads about 13.67 before starting
That came up as well in my thoughts, but I believe the alternator is the stock 30 amp 1968 / and when tested at O'Riellys they tell me it "passed"So your alternator is doing squat and 13 minutes in your ignition system goes into clusterfuck mode from low voltage.
I think it might be, I got from Mancini a bit ago, but it is brand new and just put on for this build. I'll need to check that for sure tomorrow. So you think it's rushing fuel past floats...clear filter is full.A long shot. Do you have a Carter mechanical fuel pump on there. I don't know the P/N but it puts out to much pressure. @khryslerkid knows it.
