The problem pump number is Carter M6903.
I don't care what it tested at, it's not charging the battery. Like I said leave the charger on next time you run it up so you know you have 13+ volts and see if it misfires.That came up as well in my thoughts, but I believe the alternator is the stock 30 amp 1968 / and when tested at O'Riellys they tell me it "passed"
Will do.I don't care what it tested at, it's not charging the battery. Like I said leave the charger on next time you run it up so you know you have 13+ volts and see if it misfires.
Car is not knocking, fires right up and very strong. reving it sound super strong and tight, then after warm at idle it bangs in exhaust. Sometimes a couple of big bangs. But, since I went thru plugs second time, the bangs at idle were not to loud. But, in fairness, I shut it down once it started to pop. It seems to be out of passenger pipe to me. A couple of firecracker bangs, 3 run sessions ago.knocking?
ya, no knocking, I meant exhaust bangingyou mentioned knocking in the previous post....... just clarifying
Run the 12 amp and I'd do it first before you bother tearing anything else apart!Then at same time of restart, I'll keep charger on battery during run charging at 12amp setting on charger (only have 2, 12, 50 or 250 amps on batter charger/jumper)
- or I can hook up small 6amp charger Dadsbee?
Wiil do...ya plug removal is a painRun the 12 amp and I'd do it first before you bother tearing anything else apart!
I'd be really curious to know what the actual fuel pressure is from the pump. Much more than 5.5psi can open the float needles and flood the motor out. The 13 minute window is curious.Yes, it is a Carter Fran Blacker
Fits: 400, 440
Fuel Pump, Mechanical, Muscle Car Series, Chrysler, Dodge, Plymouth, Each
Free Flow Rate: 29 gph
Maximum Pressure (psi): 5.5 to 6.5 psi
Inlet Attachment: Stock
Inlet Size: Stock
