Thanks for the reply and yes, HH is always a great help in all things electrical - and that chart is well known,
of course - but it doesn't really help when it lists several different impendences for the same ECU, nor for
different coils with the same this or that - not to mention, there's no years or engine applications listed, either.
I always took that to mean you had a window of acceptable ballasts for those same units, since that's what
the chart indicated....not much help when you want to know what MOPAR actually sold in the conversion kits.
Yes, I'm making a big assumption that what Ma sold was correct out of the box here, but I'll go with it if I can
find out what the heck it was...
And by the way, the Mopar "performance electronic ignition conversion kits" used a single ballast and in the
instructions, it specifically says how to wire a car that had a dual ballast to it, that those were "unnecessary".
I've got a copy of the installation instructions for the old kits (well, the ones being made in the late 70's,
anyways) in PDF format that I could probably copy/paste into a large post on here if anyone would like
to see it.
Unfortunately, it does not specifically list individual kit components by part number (or by rating, in the case
of the ballast). I have been told by a couple folks who should know that the ballast in those kits was 0.8ohm
rated - it would just be nice to know for sure.
Another thing that interests me is the reference by more than one that we must use a coil made specifically
for electronic ignitions, when I just saw again that Ma didn't change coils from the 60's on to 1978??
Same coil, whether points or ECU eh?
As an aside, I've been playing around on the Standard Ignition website (great source of info since 1919!)
For my 1968 (standard points), it shows for a stock ballast:
Part # RU-4 (single ballast)
Cold Resistance:0.5-0.6 ohms
Operating Resistance:1.75 ohms
(It shows similar through 1972)
For a 1974:
Part # RU-14 (dual ballast)
Cold Resistance:1.15-1.38 ohms
Operating Resistance:4.75-5.75 ohms At 25 Degrees C
So I gotta think the ballast change-over mandated in the Mopar conversion kit is significant??
