Dave145
I'm not entirely sure what's back there honestly. It kind of looks like a bushing from the outside, but I'm not sure because I haven't really studied it too much.
I took some measurements today before the show started in regards to the motor/trans/rear end positioning as well. The trans is biased toward the drivers side of the car by what I'd guess to be between 1-1.5". The rear end is biased towards the passenger side by 1/2". The trans measurement I kinda just eyeballed, and the rear end measurement I took between the outer sidewall edge of the tire and the fender lip. I don't know if the pumpkin would be shifted to the passenger side (indicating both axle shafts are the same length and the rear end is just slid over), or if the pumpkin is actually centered and the axle shafts are indeed 2 different lengths. Both the rear end pinion and the trans tailshaft weep fluid as well.
I went back and did a reread of this 5 page thread looking for your engine and trans mounts answer. They are original? I would not stop now doing as much as you have already. Spend a few more bucks and change them out.
