miller
Expert? Me???
I really gotta wonder how the hell it got so crooked.
I do agree that it looks crooked as all hell. It's even more obvious when you look at the trans flange from the rear axle. The driveshaft is on a real steep angle between the trans and the rear end because the trans is cocked sideways.
Tonight I will try loosening everything tonight and see if I can get it straightened out. Optimally it'll easily come right into line.
Do you have a service manual for the car? Should show how all three mounts are set in place. Guess anything is possible, especially with what your dealing with.Someone put the motor mounts in wrong
Dave have you determined if there is a ball or needle bearing or a bushing in tailshaft of trans? My tailshaft bushing was only worn .015 or so an it rattled bad at 3000 rpm. I took it out this weekend for first time after replacement , 3500 rpm no rattle. .015 isn't much movement but at speed.... While you have d shaft out take another look.Good to know. Pretty much took my dad's advice on that one. He's been doing this for a good while, but yeah I agree now that I think about it. Last thing I need is something else to get bent or broken!
