padam
Maybe you can give us a hint. May help someone avoid a similar problem.
No.If it were your hard earned money that you spent on a new rotating assembly would you be a happy customer when your crank showed up looking like the same used up, patched up stuff you were trying to avoid by buying new parts?
68 HEMI GTS
You sir are showing great restraint.... Still haven't put a name to the company that hasn't made it right...
I am no fan of weights welded in like that. The centrifugal force throws them out and the do around the same damage to the engine as an artillery round.
Those cracks will often occur when welding dissimilar metals and cooling to quickly and not keeping the inert gas after flow going.
You would think they should have added some Mallory to the counterweights.
Glad to here they made it good.My post may have been misunderstood. They did supply me a new balanced crankshaft. It felt somewhat reluctant but in the end they made it right. It took 2 road trips across the state as well as lots of labor, supplies, and gaskets though to fix the initial screw up.
I seen a small block ford chuck Mallory out to the counter weights on a dyno that were installed radially. Destroyed everything. When I pulled the old crank out and seen that it was a hell no for me.. I even told them I didn’t want it done that way.
Jeez…I was lacking confidence in the balance job on the new crank. Took it up to my buddies shop and spun it. Was 20 grams heavy on the front and just over 30 heavy on the back. I had a feeling it was a slam it out the door job..
What. Not the second time around??I was lacking confidence in the balance job on the new crank. Took it up to my buddies shop and spun it. Was 20 grams heavy on the front and just over 30 heavy on the back. I had a feeling it was a slam it out the door job..
Yeah, if they took out to much a second time I'd be expecting to see your name on the police blotter...It’s fixed, they at least left weight to come out this time.. lol
That’s crazy just the same. Good that you were able to check / correct locally. Should go well from here on out.It’s fixed, they at least left weight to come out this time.. lol
I had mallory metal put in a 426 hemi crank once , it was pressed in , and never gave us a problem in yrs of racing it , a failed thrust bearing finally got it < was my fault tho...I am no fan of weights welded in like that. The centrifugal force throws them out and the do around the same damage to the engine as an artillery round.
Stories like this are why i have a hard time trusting anyone to do workI was lacking confidence in the balance job on the new crank. Took it up to my buddies shop and spun it. Was 20 grams heavy on the front and just over 30 heavy on the back. I had a feeling it was a slam it out the door job..
He will have his reasons for not naming the shop publicly. If you still need to source parts from them or for some other reason it is not worth getting in to a possible **** fight.
You just suck it up and get on with it.
Nice build! Sorry about the troubles but, we all go thru them. I know I do. I look forward to seeing the car in 2024!It’s fixed, they at least left weight to come out this time.. lol
I'd be on the phone often enough so maybe they would get it done. Remind them you waited to get you unbalanced motor and shouldn't work all the way through the line! Get a firm date,almost 4 months WTH to fix their F up.I feel your pain (Literally) no motor yet since I sent it back for rebalance on 9/27......
