furious70
A turbocharged 383 is fun. It's not cheap or simple tho. But rewarding.
392 cam in a 5.7 changes it's attitude some
383 bore may be smaller, but 4.25" is still pretty good, it's the same as a Chev 427.Man, I've forgotten all the numbers......but a 400 block and 440 crank makes 451 iirc. That's also a good combo. Don't know about the 383 combos since the bore is smaller as I like big bore engines.
yeah, if i understand properly lower torque will make the converter not flash as high? so that could be a lot lower than 2800... is it doggy all around or just from a stop?No, it is an 11” that was built by Lenny at UCC for approximately 2800 stall but that was behind the 440/493. I used the trans and converter from the red car when I swapped a 5 speed in it.
Maybe it does stall too low for a 383. Good point.
couldn't hurt... with 3.91s i would think that thing would be zippy.. i never used that cam though.. my 400 had a .484 in it and LOVED that camOnce I'm up to speed, it picks up nicely. It was first put on the road with a 3.23 and ugh...it felt way too slow. I have a 3.91 in it now and while it is better, it still lacks the snap of the Dart or other Charger.
I have another factory "Hi-Stall" that I got some time ago. I had it gone through at a converter shop in town. I could swap it in in half a day and know if it helps.
