Thanks RRick, was planning on bottom end girdle also. Was planning on a progressive controler to help soften the initial hit. If you don't mind would you share your set up/ET?
This was built about 20 years ago.
Chassis - 68' Dart, 2700lbs, full cage, SS leaf springs moved into the rail, widend rear tubs, 8.75" 4.10 SG rear, 12.5x29.5" slicks, 727 with a J converter, lots of fiberglass body parts, and no interior.
Engine/trans:
68' 440 with stock LY rods and steek crank. ARP bolts throughout, TRW 6 pack pistons (too heavy!) with extra big/deep valve notches, MP 590 solid cam, crane 1.6 rockers, triple springs, template ported 915's with 2.14/1.81 long valves, Hooker fenderwell headers, old Weiand tunnel ram, 2x660 center squirters, Accel BEI ignition, homemade deep oil pan, windage tray, and a bunch I am forgetting.
Trans was a full manual 727 with a J converter, and a griner brake.
Car went 10.80's on the motor on pump gas, and 10 flat spraying 2nd and 3rd. Needed better heads, ignition, and chassis work as it would spin in first on the spray. How it was, it probably could have gone a 9.90 on real good conditions.
These days, I would build a 451 instead, with aftermarket heads and a single 4 barrel and probably run much faster without the nitrous.
