The compromise in this case is the automatic trans. A TKO would make this goal much easier to attain - deeper 1st, higher final, and no converter slippage...not as consistent, but it's a street car. A lot of builders also have to make compromises due to customers not willing to spend a bit more on the 'good stuff.'
I'm assuming this is directed at me. It is incorrect to state you need more cam for increased head flow for a given combination. For any fixed mass flow (hp), a higher flowing head's valve will not need to be open as long as a lesser flowing head. Also, the more efficient the head, the less overlap is req'd - the intake ports simply don't need as much help from the outgoing exhaust to fill the cylinder. Heck, many modern V8's have negative overlap figures...which provide a silky smooth idle and better emissions...all while making way more power than any of the 'old' stuff. This is also one of the reasons why a cam swap in a modern Hemi or LS is worth significantly more power than say a 1st gen SBC or SBM - they are cam limited, not cylinder head limited.
Take a few minutes to look at what the OEMs are doing...then what people are doing w/ those same engines to see the results they are getting...
