Best thermal and sound insulation for floor and headliner
Charger Fan
7:42 PM
Jupiter FL
I'm close to installing the new carpet and headliner on my '73 Charger. I want to install good sound and thermal barriers on the floor pan and roof before installing either. There are lots of products on the market with various prices. Any recommendations on a good overall product out there that will achieve both thermal and sound barrier protection?
Good ol Dynamat, but the stuff is stupid $$$.
Just checked the links at the bottom.
I just ordered some of the el cheapo stuff for around $1.50 a sq. ft. should be here in a few days will get back if its any good for install, adhesion, etc. Bought the Dynamat before, was nice stuff, but around $7 a foot. that's a hell of a price difference. I could double it up and still cost less than half.
Some people use the insulation that is used on furnace ductwork. Say they like it. Home Depot sold it at one time. It is butyl and silver, I did our car with it. Whenever I get it finished I will find out how quiet it is.
Maybe stating the obvious, in generalities, insulation solutions for thermal and acoustic issues often have opposite attributes. Best solution is to use a sperate solution for each issue based on need. Everything else singly is just a compromise to some degree. Both solutions are tasked usually with reflecting the concern, or dampening the concern, and sometimes both. There are no silver bullets. Each case is different.
Case in point, reflective surfaces reflect infrared heat well. However, having it on the inside surface of an interior primarily only efficiently reflects heat back inside the car, but it sure looks pretty. Dark/Black surfaces emit heat rather well vs light/white colors. Acoustically, mass dampens sound well, light thin materials do not. Thick stiff, solid materials reflect sound better.
The best and most overlooked solution IMO, just reduce the source of the problem first.
I used Kilmat on the floors and in the doors of my 69 GtX. Behind the rear seat I used a repro cardboard barrier that I covered with self adhesive duct insulation from Lowe’s. Made a huge difference in sound reduction. I’m very happy with the results.
I like this idea, does it have adhesive backing? Was it a challenge to press-fit it in place?
the whole backside is adhesive, it's basically beutyl (can't spell it.. the tar that holds windows in) you can cut it with a utility knife, peel the back and press in... i got both killmat and i think the other was siliss (on amazon) it's all pretty much the same.. don't overpay for dynamat
No, the furnace ductwork insulation has to be glued in place.
I used this.
Spray both the insulation piece and the area you are sticking it to.
Wait a couple of minutes then apply.
I use a roller wheel to shape it as shown.
I first installed a layer of Nudura self stick butyl waterproofing membrane, and then added the Siless 157 mil reflective membrane from Amazon over that. This made a noticeable difference in both sound and heat transfer through the floor.
I used Kilmat on my 65 AFX Coronet, got it from Amazon along with a set of 3 rollers to form it to the floor, cut with a pair of scissors want down easy using the rollers also from Amazon. I covered all the tubs and back package tray, would have had more pics but camera took a dump.
