76maverick
I believe I am getting a good deal on a 451 with 12.5 compression. The down side is that is has 12.5:1 compression. What would be the best/cost effective way to lower the compression to 10.5:1-ish so I can run it on pump gas ? Here is the specs I have: 12.5:1 compression steel 440 Crank LY rods, Ross 14.00 CC dome Pistons, balanced rotating assembly, 452 heads, extreme energy cam 510 lift.
Thanks !
Thanks !
