Looking for crisper and higher shifts in my 62 Belvedere, 3184bbl, 727 pushbutton. I rebuilt the transmission 4ish months ago and like a dolt didn't contemplate installing a shift kit, servos, governor kit, etc. I did add bolt in sprag, kolene steels, upgraded seals, PTC converter.
I want to keep it automatic shifting , no manual valve bodies needed. Street car with factory pushbutton 727, rear pump. Looking for wot shifts around 5000. Nothing crazy.
Go shift kit or valve body? Transgo TF2 looks decent but CRT has a complete valve body for $225. Would this be the same as adding a kit only no hassle of swapping parts? Also guessing low/reverse servo needs upgraded in either case.
Do I need to get a governor kit as well? Trying to get around it 8f possible. Pulling the tail housing in the car looks like a huge pain as I just welded up the exhaust to fix some leaks.
Any recommendations?
