Dodge Bros
I think you could likely get past that 500 hp goal and manifolds using a stock crank, well chosen cam and stock type heads with 2.14/1.81s and some bowl work, but not easy on pump gas.. Personally I prefer the solid flat tappet cams over a roller in combo’s like this, and without a ton of port work the gains are small from the bigger lifts. In a 440 with manifolds the old 528 purple cam was a contender. Bigger cubes I think I would go bigger yet though.
Back when we built circle track engines there was a class of hobby stock that had to run stock exhuast manifolds, carb, no roller rockers.. ect...allowed very minimal porting, but with no cubic inch limit. One of the guy’s built a 452, 400 with a 440 crank, flat top pistons, it had 452 with 2.14/1.81, the bowls were basically cut straight down from the last 3 angle cut then blended into the port. It had a Engle mopar design solid flat tappet cam, 250s at .050 tappet, sold by Hughes at the time. Nothing fancy by today’s standards, I think it was a little over 500hp IRC.... Man did it run. Up against some high dollar engines it made them all look slow. But it took race gas.
That being said, I think it is a little easier to hit that 500 mark with a bigger crank than a 440 crank. We have had a number of different combo’s in that range, usually with headers though. Our most outrageous bb combo with HP manifolds is a 542(4.5” crank in a 72 400). 2.14/1.81 ported 346 heads, HP manifolds, stock intake, and a thermoquad in a 72 Satelite. Bullet solid flat tappet cam right around .6 lift. We built it to run in stock type (F.A.S.T.) class’s, but as a driver on pump gas. No interest in doing a roll bar, will be content with low 11s...with 3.23 gears and a tight 3000 rpm converter. Going together right now with it. Looks like it is a stock 400 with A/C.
One thing we have noticed going with the big cubes is will make a good sized cam in a 440 act like almost like a RV tq cam in the 500+ engines. To small of a cam in a cast iron headed open chamber, doesn’t take much compression to push the limits on pump gas, the HP manifolds probably don’t help either.
