- 1:33 PM
- Apr 13, 2012
- Granite Bay CA
My recent experiences with automotive air conditioning installations have me curious about modifying hard lines to make a more custom fitted system.
Here is an example.....My own '70 Charger.
The #8 aluminum line is prebent by Classic Auto Air to fit around a battery. My battery is in the trunk. I would like to have the ability to shorten the hard line like this:
To do that, I need to learn how to braze aluminum.
I've never welded with a torch so I'm learning as I go here. I can stick and MIG weld, I can solder wires but that is about it.
I have a few Propane and Mapp gas cannisters like these:
So far, the most commonly found nozzles look like these:
The cannisters warn against inverting them when in use but how am I supposed to apply the flame when the work I'm doing is barely above waist high? I'm not trying to do the work overhead where the nozzle points. It would be great if there were nozzles that had a swivel.
With these types of nozzles, You have to tilt the nozzle to get it where you want it. There are those nozzles with a hose that I could try.
I recently was at an A/C shop helping out a friend with his Coronet. You might remember the guy....
He had a line shortened and brazed back together and it got me thinking.
What ONE man can do, another man can do. If I can get good at doing this, I'll be able to route A/C lines wherever I want and not be limited by the stock sizes that you buy at the store.
My first effort SUCKED though.
