resq302
So after a few months of driving the car around and having fun with it, I started back on getting the car completed. I am looking at having it finished for the Mopars @ E-town show on Aug. 23rd. Anyway, here are pics of the rear axle with the resto. I gotta say, I can honestly say that this appears to have never been apart as the wheel cylinders still have the white closed cell gasket material on it. The markings I am finding on the car are ones that I have NEVER seen before on other original cars that I have looked at!
u bolts and rear rubber flex brake line bracket all degreased
rear leaf springs.....
pinion snubber with TONS of grease on it. Once it was cleaned off, the rust seemed minimal and most likely will be pit free! (currently soaking in evapo-rust!)
original rubber bushings for the shackles...
hard to see but appears it was a yellow 4 on the third member a the 12 o clock area.
original rubber flex rear brake line...
hardware....
some yellow mark on the underside of the rib where typical area for the stamped date code would have been.
heart shaped yellow crayon mark to the left of the 2
orange mark at the 6 o'clock rib, most likely for or part of the axle ratio
yellow paint mark on the saddle of the driver side axle tube
another yellow paint mark on the pass side axle yoke as well as a baby blue dot (with splatter)
paint markings found on pinion yoke. red where the caps are and white closer to the nut
more paint markings on the driver side axle tube. markings were put on with the axle flipped 180* so the carrier was facing rear ward as shown by the paint runs from the inspection marks
original wheel cylinder still has the factory white closed cell gasket material! (how often do you see this!)
factory installed u-joint straps (previously pictured earlier in the thread but the picture turned out blurry)
yellow inspection mark on top of the axle tube and went UNDER the brass t block for the rear brake lines. vent bolt put back in place to prevent dirt from entering the axle.
factory gray dip tank primer where the front hangers were bolted up.
factory red oxide primer in the wheel wells where they missed with the undercoating.
bronze paint over spray in wheel well and also area where the lower black out got over sprayed
reference pics for when I put the brakes back together!
axle u bolts all cleaned up which revealed white inspection paint marks on the top of each u bolt!
hardware....
