So its been a while since I've done an update as to the progress. Some of you might have seen the issue we had with the new Mr. Gasket "fail safe" thermostat which ended up failing in the close position. So much for being "fail safe"! Anyway, on Monday, I started tearing into the front suspension on the car in hopes to have it finished up and buttoned back up in time to take the vehicle to the Slate Belt Mighty Mopar show on Father's Day. This is how the front end looked when I started the work.
some knuckle head painted the body color area with black paint.
I think I must have broken a record or something as I had the entire front suspension out in about 3 hours!
Here is something that is weird..... both fenders have what appears to be a access plate or splash shield missing. The screw holes are there but have no threads cut into them. Factory mistake maybe? Or did the GTX never have a splash shield up here where as my 69 Charger has a metal splash shield with a rubber gasket going around it. Also, note the red oxide primer!
Body color reapplied after cleaning and removing the incorrect black paint.
Undercoating reapplied with cardboard template held in place to mimick the factory process.
Cleaning up the lower control arms, I revealed even more of the orange inspection mark I had seen when it was still installed on the car.
what they looked like before!
Upper control arms. Left side is before..... right side is after an overnight soak in evapo-rust! Amazing stuff!
Blue paint from an inspection mark found on spindle.
This appears to have been a black inspection mark on the center link. This was after it was soaked in evapo-rust.
with another black stripe more towards the center.
Lower control arm after new bushing and pivot shaft installed. A nice coating of cosmoline (man that stuff stinks!)
All of the hardware and other miscellaneous parts waiting to be treated with RPM. Strut bars and center link have also been treated with evapo-rust at this point. Torsion bars still need to be restored.
