RS23VOA
Sounds more like your all a bunch of hoarders? LOL
Still pushing to start this Summer, got the Honey do list to attend to first.![]()
Yes we are!
24 aint deep enough. 30 at least. Garages are never big enough!! Go with a roll-up door so you have future space for a lift.I'm planning on building a garage this Spring and need to figure out what I want as far as size goes. I'll be building it myself and will likely go with a poll barn style only I prefer pouring the footers leaving blocks above ground with anchors instead of burrying the lumber. I came across some nice trusses years ago (still indoors) and snagged them up so if I use them I'm looking at a 24'X40 maybe 60. I'm just curious if 24 is deep enough? Since I work at a sawmill the only real cost will be the floor, garage doors and the tin if I use the trusses.
I can dig it!!Well I have been prepping the wife....our next place is going to be a 6 car garage with attached house!
24' won't be deep enough. You need 30 or 40' deep. Remember, most of your actual work area will be up front. I had some space limitations when I built mine (pic). It is 24 wide by 30' deep. That gave me about 8' of working space up front. Also went with an 11' ceiling and roll-up door for future lift possibilities. Also went with a very stout trussed roof and full attic to accommodate a 2000 lb winch for pulling engines, etc. I have a very useable insulated, heated, full attic 2 car garage in a small space.I'm planning on building a garage this Spring and need to figure out what I want as far as size goes. I'll be building it myself and will likely go with a poll barn style only I prefer pouring the footers leaving blocks above ground with anchors instead of burrying the lumber. I came across some nice trusses years ago (still indoors) and snagged them up so if I use them I'm looking at a 24'X40 maybe 60. I'm just curious if 24 is deep enough? Since I work at a sawmill the only real cost will be the floor, garage doors and the tin if I use the trusses.
Congrats! We installed a lift and it is nice with a capital N!!! You probably already know this but I would advise installing a. beam/pier where the lift is going to sit.notice a lift was added.
Nice24' won't be deep enough. You need 30 or 40' deep. Remember, most of your actual work area will be up front. I had some space limitations when I built mine (pic). It is 24 wide by 30' deep. That gave me about 8' of working space up front. Also went with an 11' ceiling and roll-up door for future lift possibilities. Also went with a very stout trussed roof and full attic to accommodate a 2000 lb winch for pulling engines, etc. I have a very useable insulated, heated, full attic 2 car garage in a small space.
Haven't put a ton of thought into that yet but was thinking about digging the floor deep enough to have a healthy 12" thick pad under the lift with 1" anchors anchoring 3/4" plate down, then mount the lift to it? I'd think a larger diameter pad 12" thick with rebar tying it all together would be very stable. A pier would be another good option.Congrats! We installed a lift and it is nice with a capital N!!! You probably already know this but I would advise installing a. beam/pier where the lift is going to sit.
We had the slab company dig a 12d x 24"w beam where the post were to be bolted down, reason being we have a friend that installed one after his shop was built and the anchors are starting to come loose. I think his was just a 6" slab... He also uses his every day...
I thought about it but won't be doing it, way to much money and I'm perfectly content without it. I'll likely propane heat keeping it 55 degrees or so and a woodburner to really warm it up when needed. The big thing is not allowing everything in the garage to get freezing cold. My problem with heated floors is it takes forever to change the temp and of coarse the money $10,000.Does your climate suggest an in floor heating system? In the cold northland I thought about it, but didn't have the time. Sure wish I would have. Gas unit heaters work OK , but the in floor stuff does a great job.
