I forgot to mention the manual valve bodyDisagreed with starting out in 2nd at the track.
You end up actually starting out in 1st, without applying the band. Like starting in drive.
Always start in 1st with a fully automatic 727.
Then they lay under the 4300lb car with only a floor jack... Dumbasses
I'm sure some of you have seen an or heard about an episode of Uncle Tony's Garage (not that i watch it) where he's insisting some guy do a burnout. Anyways, the guy blows up the transmission and is lucky to still have his feet. How do you avoid blowing a 727 by doing a burnout? I saw some talk about not letting off until it shifts to second?
I think the second part is a bit confusing..TA saying its ok to do a full power burnout but not ok the let up on dry pavement. The engine has to decelerate at some point in either case. I always assumed the quick jerk off the gas when it's running rpms and the tires grab (in first) the shock can kill the sprag coming from the tires. Cope exploded his somehow hitting reverse accidently. The sprag obviously can't be taken out if it is not doing anything. 904s and 998s already have a bolt in sprag and less mass. It's the combination on the 727 large diameter cast front drum and sprag that is not bolted that require upgrades for serious performance. A car with street tires and a mild motor it is possible to take out the sprag clutch...but there is a huge difference taking 700hp and 14x32s slicks at the track while doing a improper burnout vs a street 275 radial and 450hp on a highway no rubber. Copes videos are the best I have seen.Those TA instructions seem rather confusing?
Mike
I've heard of "exploded view" in service and parts manuals, but right there at the track?! DANG!!
This video by Cope Racing explains it very well, and with visual aids:
Here is a previous discussion of that video:
Interesting 727 info - exploding transmissions - John Cope
Why does mine freewheel in first. I have no compression braking in first. Art Carr built mine. Did billet hub, everything. He said it was now the same as he built them for the early match race cars. Told me up to 1500 hp with big slicks. Cost me 4k with converter, installed. Was he wrong. Great video… thanks for posting it.That’s exactly what NOT to do with your 727. Never let off in first with that valve body.
Yours is the original no-low gear band apply valve body. Supposed to be microscopically faster, and have a cleaner 1-2 shift than the newer low band apply version.Why does mine freewheel in first. I have no compression braking in first. Art Carr built mine. Did billet hub, everything. He said it was now the same as he built them for the early match race cars. Told me up to 1500 hp with big slicks. Cost me 4k with converter, installed. Was he wrong. Great video… thanks for posting it.
