1966Charger 1.Small Block 408 2.4 speed 3.Aluminum head, intake, fly wheel and cases for the 4 speed 4.Reinforced K member and lower control arms 5.Firm feel steering box 6.Quick ratio pitmen arm and idler arm 7.Adj. strut rods 8.Heavy duty tie rods 9.Poly Bushing on all but lower control Arms 10.1.25” torsion bars 11.Koni Adj. all the way around 12.Waiting for New upper control arm from Magnumforce double adj. 13.Waiting for sector shaft stabiles from Firm Feel 14.Tires BFG T/A 245 60 15 on Cp Wheels 15.Brakes (Less braking than Stock) SSB Force 10 disk front and SSB rear disk 16.Diff 3.55 8 ¾” with Eaton Truetrack 17.Toqe boxes 18.Frame ties 19.Adj. Rear Spring hangers 20.Custom built rear springs 21.Front and rear Sway Bars ( rear Adj.)
Known issues 1.Brakes Looking at Bare Claw 2.Tires and Wheels Need Wheel to fit over the Bare Brakes and hole Sticky tires 3.Looking at 2” Drop Spindles
Looking for Suggestion for Alignment for Auto – X with Tubular upper control arms
Nice car, David. Obviously you're wanting some alignment specs regarding good handling then.
Here's a start.
-.5* camber right and left.
2* caster left and right.
0* total toe.
You can add some caster if you have power steering. You did not specify. Like I said, those specs should give you a good start. If the steering wheel shows good returnability, you can drop caster more to improve handling. If you go down much under 1*, I suspect it will not feel good at high speed on the road....although handling will be improved. Good luck.
