Can anyone help?
If it were me I'd just switch to a Carter / Edelbrock 750... I've never had much luck with holley's myself, Isn't once you backfire a holley you blow the power valve???
Carters are just so easy to tune..... just my two cents.
They ave fixed the power valve problem. What color are the plugs ? If they arent fouled soot black you probably aren't to fat.I have heard the avenger NCTM numbers are exaggerated.
I found the packet from the performance shop that built the engine. Here are the particulars:
1) Holley 0-80870 Carburetor, Street Avenger, 870 cfm, Square Bore, 4-Barrel, Electric Choke, Dual Inlet, Silver
2) Eldelbrock Performer 383 INtake Manifold
3) Comp Cams 23-224-4 Cam Shaft (Camshaft, 3-Bolt, Hydraulic Flat Tappet, Advertised Duration 274/296, Lift .488/.491, Mopar, Big Block)
4) Ported and Polished 440 85cc Heads
5) Compression Ratio is 9.59:1
870 CFM :eek: You have too much carb! I bet that cam would be better off with more compression too. Another question. What is your cranking compression PSI?
same prob here(also on a 383/727 combo and i only went from a 600 to a 750 both holleys am seriously thinking of going to a eddlebrock
