Can I use the MSD Blaster 2?
TheSwede
1:43 PM
Malmo
I am planning to buy a new coil and wonder if I can use the MSD Blaster 2 with my mopar electronic ignition system, do I have to mount the coil vertically or can I mount in on the intake horizontally? Do I need the ballast that comes with the coil or the one that sits on the firewall or none at all?
I just want a coil that works and fits on the the intake. Any suggestions?
The Blaster 2 should work fine. Keep the ballast that's on the car. (MSD and Mopar use the same ohm rated ballasts, keep the MSD one as a spare).
I know people that have this combo and nothing bad happened after many miles of use.
MSD says it's universal. I have one on my 63 plymouth for over 10 years now and it works great.
MSD says not to mount it on its side, know a bunch that do and they have been fine so far. I run one upright with a mopar electronic ignition with the ballast that was there and have no problem. Carry a spare ballast resister with you at all times though. Mopars are known to have ballast resisters go out for no reason. Heat eat them up over time.
OK, thanks, will order one tomorrow.
