Glenwood
- 1:12 AM
- Jun 19, 2015
- Kawartha Lakes, Ontario
Some good tips here...thanks guys!
I used 1/4" holes, thinking about the same size as the original spot welds. But, for each spot weld, I drilled a 1/8" pilot hole centered on each weld, for the spot weld cutter I used. Probably past that on your's. Also wanted the holes to use as a guide, to mark on the new pan, and drilled those locations.I was thinking of drilling 3/8 holes because 1/4" might fill in to quick before melting into the thick frame. Maybe a test piece is in order?
Good as new! Looks solid.
Yeah, on the brackets. Might be able to look at the bottom side of the old floor pan, up front near the hump. Should go on at an angle.Although I also have a couple of small brackets that came with the pan. Nigel up at National Moparts said they are for the speedo cable but I have no idea where they would go. Mine probably rusted off lol.
Yep, e brake and parking cable. I honestly cannot remember if that plate is spot welded or not but I think it would fine without welding.That is so helpful threewood, thanks so much!
Which cables are passing through? Looks like the e-brake and park cables
