Cannot Remove Brake Pushrod From Rear Piston
boboh1
5:41 PM
Claremont,CA
Replacing my brake master cylinder. When I removed the old one the pushrod would not release from the pistons. I got this left to remove but it won’t budge. Is there a trick to this?
Clamp the rod in a vice with about 1/4 inch of space to the piston. 2 large screwdrivers one on each side and it will pop right off.
Thanks for all the advise. I do have a vice. Man it is in hard. All my other cars in the past the rod just slid out easily. Now I hope the bolts can be pounded out from the old MC
If you are reusing the studs, put on nuts to save the threads and tap them out with a hammer. Just tap them into your replacement MC. I had to use JB Weld to secure them into a new MC with larger holes. Worked well.
Mike
The "trick" was to pull it out while the master was still on the car. Do as Dadsbee says.
You can put that piston on a hard surface and whack it with a hammer, it will break.
So, were you successful getting your hard rod out of the hole ? And, when pounding the bolts watch out for your nuts.
#10, you should have did it when it was still in the car, you still can.
^^^ The only thing holding the piston in on a manual master is a little tab screwed in place. Not gonna hold a stuck rod... just gonna bend out of the way.
I was able to pop the rod off using a vice and a big screwdriver pulling it upward. The old MC looks to have pressed in studs. I will probably have to order these. Hopefully I can carefully hammer them into the new MC
Put a nut on each stud, clamp the m/c in a vice and one hit with a ball peen will knock the studs out.
? Why not rebuild what you have vs a replacement?
Sorry, wasn't aware of a retainer clip. All that I have dealt with just had a small rubber hose like retainer in the recess of the piston. Just grab the brake pedal while still in the car and pull.
Is this little tab in place simply for shipping purposes? The cylinder won’t fly out if I remove that retainer will it?
