Jim 68cuda
Looks like the only upper hose anyone has for a big block is for the 26" radiator. Got one from Rock Auto and it not gonna work. That one has the inlet on the passenger side of the radiator. In 67-68, the 22" radiator had the inlet on the drivers side. I then figured I would ask my local parts store for an upper hose for a 383 in an A body as the 22" radiator would have been the only option. The result was suggesting a flex hose. Figured I would try for the hose for a 68 340 A body as those would have the 22" radiator and the thermostat housing is in about the same place on both big block and small block. Same results, a flex hose. Same results for a B body 318. Anyone know if any molded upper hoses will work?
