Hi I can't figure out why my passenger rear drum is overheating on my 68 charger. With the wheel off the ground it rotates freely with no drag buy everytime I go for a drive the drum gets extremely hot. I've tried backing off the adjuster a dozen times to the point it's all the way in. I thought the drum was warped so I replaced the drum three times. I checked run out on the axle to see if its bent and it is not. My parking brake is not the issue I've even disconnected it. It all started when I changed the 10" drums to 11" ones. I installed a used set of 11" backing plates and levers, new wheel cylinders, new drums, shoes, springs and hardware. Any ideas?
