dave5237
The car should start in neutral the same as if it were in park. Try this, turn key to run position, with engine off, and place shifter in reverse. See if the reverse lights are on. If not, double check shift linkage adjustment. Then check the neutral safety switch wiring. The neutral safety switch goes to the starter relay. Next to the master cylinder. Make sure you have that on the right terminal of the relay. And check the switch with an ohmmeter too. Also you should check to make sure the wires are going to the right terminals on the NSS. Do you have new wiring or the original harness?
Thanks. I have a new wiring harness. I know when I started it in neutral the first time I tried to get it going for the first time I heard a lot of popping or sparking. I just figured I could not do this. YOU MAY BE ON TO SOMETHING. Will try this today.
