I own two trailers and move tractors around to shows here in NY. According to the DOT, if you are not engaged in commerce, the DOT tie- down rules don’t apply.
Part # Length Unit Weight CURE38-8200C 14' Long Straps KIT 27 lb CURE38-8218C 18' Long Straps KIT 28 lb Carrying bags are included with Kits! *Limited Quantity Description INCLUDED: 4 gradual release ratchets, 4 long straps and 4 short straps In 2013, our team at B/A Products Co. designed a...
I used a chain, ran it over the diff and to the back corner D-rings. Then, one axle strap each side to the outboard-most point of the rear axle to that same side corner D-ring.
Up front, it was lower A-arm with an axle strap, then a large tie-dye to the same corner D-ring, for both lower A-arms. The winch held an axle strap around the front crossmember (or center point of the front straight axle). So, there were six points of connection, in all. Never lost a vehicle. I didn't care for crossing straps or chains, as I'd seen that chafe the straps.
