Meep-Meep
дворянин
I found most carb problems come from the ethanol blended fuel. This stuff does not like to sit in a hot fuel bowl and the best you can do to minimize the typical problems is to block the heat crossover in the intake and put some sort of an insulated spacer. Even that won't cure the issues but will help. The only known cure (in my opinion) is fuel injection - even the throttle body type.
If you have a bone stock motor a 650 AFB with the slightly smaller primaries would be my first choice, especially with stock exhaust manifolds. A 750 will work too but you may have a stumble when mashing the go pedal under load. The Holley 750 vac secondary with a heavy spring in the diaphragm will be more forgiving under full throttle / heavy load conditions. With carb CFM it's always best to err on the conservative side. And I will say this again, make sure you get a carb that has street calibration.
