Al K
- 1:40 PM
- Nov 15, 2009
I had to run an additional wire to the battery (or starter since it is trunk mounted) when we were having voltage issues. The car would only charge around 11.5V when it should be 13-14V. If it is an everyday driver, eventually this will lead to a dead battery, especially while cranking over a higher compression engine. The factory wiring was not sufficient for even the 65AMP alternator. An easy way to check this is to simply cut a piece of heavy gauge wire, hook it up to the battery post terminal on the alternator (as an addition to the factory wiring) and hook it up to the positive side of battery or even the starter relay if the battery is trunk mounted. If you see your voltage increase, then obviously you know it is your wiring.
What gauge wire did you use for this? Any minimum/maximum gauge recommendations? I'm fighting a low voltage issue myself-with all new alt/reg/ballast resistor/good battery and I'm stuck at 11.2 volts on the inside gauge. Gauge checks out. Bulkhead connections cleaned and greased. I'm following this thread(all three chapters) to see if I can figure this crap out before I post my own thread on the matter. Thanks!
Carry on...
UPDATE!!! Had some 14 gauge around,so I made a jumper running from the alternator stud to the starter relay. Figured it might be too small,but I've been f@#$%&*g with this for a week,and was ready to try something. Guess what? IT WORKED!!! I started the car,saw the gauge sit at 11 or so,and then...the needle started moving-in the correct direction! Settled at around 12.2 at idle,went to 12.5-6 when revved. Way cool! I still want to go to larger wire,either 12 or 10 gauge.
