Depress the pedal to the floor which stretches the spring and slide large washers between the coils. Let the pedal back up and the spring will come right off the pivots.Anyone got a go-by on removal. I’ve spent too much time under my dash lately replacing the master cylinder and pulling/replacing the steering column.
Thanks. What is the effect on normal clutch pedal effort and motion (variation in effort with travel, hitch/over-center points, etc)?Depress the pedal to the floor which stretches the spring and slide large washers between the coils. Let the pedal back up and the spring will come right off the pivots.
It has been years since I drove a diaphragm clutch but they have a lighter pedal feel and resistance. Easier to depress and the return spring is not needed by design.Thanks. What is the effect on normal clutch pedal effort and motion (variation in effort with travel, hitch/over-center points, etc)?
Yep... 383 x 4 gear in my Wife's S....my wife drove the borg and beck in her 68 340-S just fine, so it can be done.
Sorry to ask. Checked with service manual which helped where this part is of the overall assembly. But just need to confirm where I look. Embarrassed but rather ask. Is what @toolmanmike is referencing in post #2 about an access cover or is the linkage exposed?So... you should be able to pull back on the fork, via the washer, so that the throw out bearing hits the pressure plate and have about 3/16" of slop between the washer and the nut. Adjust the nut until you have that "free play".
View attachment 1803712View attachment 1803713View attachment 1803714
Look underneath and you will see a sheet metal inspection cover.Sorry to ask. Checked with service manual which helped where this part is of the overall assembly. But just need to confirm where I look. Embarrassed but rather ask. Is what @toolmanmike is referencing in post #2 about an access cover or is the linkage exposed?
I bought a 68 charger 4 speed years ago. It had a diaphragm clutch and pedal would stick to the floor, needing an assist with the foot to come up. Found the over center spring, removed it and was 100x better. I no longer want a b&b pressure plate.
69 rr was same way, or maybe I changed that clutch myself from b and b and the spring had to go. Can’t remember. I do know both cars I couldn’t get anything between those coils. Nothing. It’s like the coils didn’t change as the pedal was moved. More like it pivoted on the mount points was all.
So put on the best protection I could and dremeled my way through them. Sounded like a gun blast. I and the cars were unscathed. I recall lining up the blade and getting my head and neck above the area and kinda had my body to the outside of the car. Definitely the most scary work I’ve done on a car.
Did you have permission to take that picture? Or is she just seriously paying attention to the road?Yep... 383 x 4 gear in my Wife's S....
So... you should be able to pull back on the fork, via the washer, so that the throw out bearing hits the pressure plate and have about 3/16" of slop between the washer and the nut. Adjust the nut until you have that "free play”
Spring there should be nothing stronger than what is need to hold the throw out bearing off the pressure plate and keep the fork from rattling. That spring looks mean.. lol. Hold the adjuster rod, pull back on the fork. You should get a gap of about 3/16 or so...Is this the right? I don’t see where mine has really any space between the washer and the nut? Or do I have to pull back on the fork first to check gap? The spring on mine looks like a heavier gauge? (if that actually means anything)
What do you think?
Oh btw, “Sidestep”? What do you mean.You should be able to side step a clutch pedal and dis-engage and re-engage a clutch when into it.
