Clutch bell crank bracket location on a 69 Charger
Stucat
11:51 AM
Looking on converting my 69 Charger to a 4 speed. Have all the parts, but need info on locating the clutch bell crank bracket. The engine is not installed so I have plenty of room to work. i found the bracket, but no measurements on location included. Thanks for all the help.
looking on converting
Looking at the inner fender and frame at the access hole there is a notch in the frame that a new weld in bracket tab will fall into if the frame hasn't been modified. Iv'e done a couple of them.
thanks for all the insight going with the original setup , have all the parts. And yes over a grand for all the parts. Looks like a 10 minute job to put the bracket in. Thanks
Good luck getting it all in. For me a 10 minute job turns into all day and 3 trips to the hardware store. May it go smoother for you. Please post some pics and commentary to help the next member that wishes to do this.
