For the B&B style, the cover springs need to get the pedal to just past "center up" for the OC spring to lift it to the stop.
FWIW, the MP book has a setup fixture that checks installed finger height as a way to find out. They don't say how it's used .......
I use a ground disc in between the cover and the flywheel bolted down. Measure down from the fingers to the disc with a dept mic for the 1.700".
View attachment 1579999View attachment 1580000
A few things I've noted over the years if it can help....
A disc that is too thick can drive the fingers down closer to the hub springs. shimming out the clutch cover may resolve that issue.
A turned flywheel, a bell crank sliding side to side, a short, worn, bent, or even wrong pivot, weak cover springs or misadjusted fingers, worn fork contact points, worn out pedal bushings, bad engine or trans mounts, and even a worn out thrust bearing can all be contributors to a low pedal issue.
dadsbee already covered the A-body adjust rod possibility.
Shims may still be available to push the flywheel rearward.
Consider the fork pivot height. A spacer under it with correct length bolts may be best as it moves both, the fork tips and the adjust rod contact point forward.
In any case, be careful on the adjustment. 0.060" is what MP calls for. Too much and you risk running the finger backsides into the hub springs.
