Dragon Slayer
You need to reread what I said. I know how it works. Your assuming for him. He may be mistaken in what he wrote, but as written in the method he used he does state he has 12.5V on + of coil in run even though he states output of ballast is 9.1. So both can't be correct unless he posted wrong, or he has a wiring issue with input of ballast on the + of coil.
If he truly has 12.5 on the + of coil while running, that certainly could explain why coils are failing on him. Which is what the original problem claims.
He could also put an amp meter in series with coil + from ballast and read amps.
