supernova1969a
Did. a. Leakdown test on my 383 110psi,on all. 8,with 15psi leak. Static. Is that any good?
Heres my resource for how to build a leakdown tester. I did it, and it works GREAT! Also how to use and interperate what you find. http://vmaxoutlaw.com/tech/leakdown_tester.htm I'm thinking on a hi-mile, low-comp, 318, 110 psi on comp test is not so bad. Tired, but not dead.
Sounds to me like they replaced some of the valves during the head work and the stems have different lengths above the retainers/locks now... or like Scott74 mentioned, new seats that are at different or varying heights. You may need shorter pushrods and/or adjustable rockers now to get lash set up properly on each valve.
Was the head "milled"? New valve seats installed?
Was the compression test done wet or dry???
I think your right, I measured distance from top of valve to top of valve spring retainer was getting big differences from valve to valve. I dont think valves are closing fully,plus when it was running could see huge flames coming out headers. What adjustable rockers do you reccomend?
