PurpleBeeper
i've used the low tox stuff before. no issue with it but IIRC freezing and boiling points are different when compared to ethylene glycol at the same concentrations. i don't think an ethylene glycol tester works correctly with it either.
You are correct. Ethylene glycol & propylene glycol (in Low Tox stuff) have slightly different densities (floating ball tester off) & slightly different refactive indexes (refractometer off). The floating ball testers & the old Prestone tester with the red pointer (basically the same thing) should work on ethylene glycol coolants, but read wrong for propylene glycol coolants.
http://www.ppe.com/pdf/SpecificGravity.pdf
