cooling need more cooling.
wow thats tight.
It's ridiculously tight, I even machined a fuzz off of the power steering pump pulley but nothing rubs. If I ever redo this car I'm figuring out a way to move the radiator forward because they left almost no space for anything in these Chargers.
I did this at the same time as I switched to a serpentine belt so I have no idea how it would have fit with V belts.. my guess is it would have a little extra space?
I looked at all of them, the one I bought fit my radiator perfectly so I'm guessing I didn't have the width for this one.
Thanks. I just read the S shaped blades of that larger one I listed is quite a bit noisier. I think you did good. Are you running a 26" or 22" radiator? I have a 26" and the one you are running is not large enough to cover the entire area of my 26" rad (not sure if it needs to - my existing fixed fan doesn't, but I'm thinking about mounting purposes).
I can measure it if you like but I'd say it's a 22" because it covers the whole radiator. The car is a 1969 Charger SE that came with a 318.
